Hi cherries, I saw that a lot of ye draw clothes and ye want to upload them in this game. My job is to mention the
quality of the clothes drewn by ye and this is why I can't accept all the ye's clothes even if they are very original, and ye's ideas are very good. This is why I made this tutorial, I want to help ye to create clothes in that have a great quality.
This is what you need for this tutorial. Don't start reading until you don't have everything:
- Photoshop
- Cherry Model, you can find it here: model-ciresica.psd (click for download)
- Patience
- Ambition
- Perseverance
The list of tools you learn how to use in Photoshop.
- Brush Tool
- Eraser Tool
- Pen tool
- Direct selection tool
Now I will show tutorials for all the tools so you can learn to use them.
Brush Tool
We won't draw everything with the brush.
http://www.youtube.com/watch?v=wRpKWv8Hyeo
http://www.youtube.com/watch?v=Z-K47-kzzC4
http://www.youtube.com/watch?v=c3sECqHNNMo
Erase Tool
I use it to erase small mistakes adjust the opacity to erase thinner.
http://www.youtube.com/watch?v=BgjxHJp_XYc
Pen Tool
This is the most important tool. With this tool you can create shapes (te clothes shapes) and
when you want to create stripes stretching clothes. After you pick the tool make sure that
at the top it's set on the thing you want, look at the picture at the right.
Before using this tool, create a new layer. When you selected that tool, every time you press on the image you will make a little dot called Anchor Point. To trace the shape or the curve lines hold down the mouse button until get to the wanted shape. To finish the shape the last dot has to stick to the first dot.
When you trace lines (you picked the second option from up there, from the right picture.) Add some dots you need, then click on the right part of you mouse, and pick Stroke Subpath then at Tool pick Brush to use the Brush settings.
Here's some tutorials too:
http://www.youtube.com/watch?v=kKsJMtTJISc
http://www.youtube.com/watch?v=tIFKmK7xpyU
http://www.youtube.com/watch?v=-zRK65pBWh4
Direction Tool
This tool helps you when you want to modify the clothes shape that you have drewn.
http://www.youtube.com/watch?v=_aqStVg1i4Q
http://www.youtube.com/watch?v=HsvZytML32Y
That's is all the stuff with essential tools for Photoshop. For the final thing I'll give ye 1 more tutorial to understand how to use effects on layers.
https://www.youtube.com/watch?v=CwNdt_kdju0
Use Layers with patterns
This tutorial will show ye how.
https://www.youtube.com/watch?v=xnk_END4yuk
If you managed to draw, the last step is to save the image as png, here's how you do that:
- Create groups wich contain all the drewn clothe's layers.
- Make a copy of all you have drewn.
- Press on the right part of your mouse on the group that contains the clothe's layers and then pick Go to the Group
- Now you will have one single layer except the group. Press CTRL+A, CTRL+C to copy the layer.
- CTRL+N to create a new image on the Backround Contents pick Transparent and press OK.
- CTRL+V To stick the drewn clothe in a diffrent image (so you can escape from blank zones).
- CTRL+ALT+SHIFT+S pick PGN-24 and click save.
